Dominique Williams
Hi everybody, just wanted to get peoples opinion on a situation so my friend did the timing on my engine i have a 440rb engine with factory estreet aluminum heads and a comp cam that’s 206 at 50 with a 750 summit carb if i said that wrong please forgive me he plugged the carb ports as well as the distributor port and set the overall timing to 38 I drove it home from work and it responded actually really well and was a smooth drive but after getting home and doing research im seeing alot of people with various opinions saying you don’t need to use it while others say its a must among checking boards outside of this site it’s said that overall timing should be between 32-36 for my engine and that I should give it wot to listen for a pinging sound to see if the timing needs to be brought down im here for any advice that will help I want it to get as much power as possible but I also don’t want to (detonate) my engine either my friend told me to drive it this weekend and if their are any problems to bring it back on Monday and he’ll hook the vacuum back up but he’s said he hasn’t used his in year and hasn’t had any problems
