turn signals and flashers are still out on the 68 300. I fear the culprit might be the turn signal switch in the column. I did find a supplier on eBay, but hoping to keep that as a plan B because of the cost of the part and not wanting to tear down my steering column.
My ideal plan A is the hopes maybe the issue is the flasher units because they are cheap. I found one dangling under the dash (don’t know if it is the turn signal or hazards). Replaced it, but still no blinking. I can’t seem to find the other. Any advice on where the other flasher unit is under the dash? Also, Are the flasher unit parts the same for the turn signals and hazards? The FSM says “heavy duty” for the hazards, but the friendly folks at the local Napa can’t find the difference.
As always, thank you!
