SOLD Free Stuff Delivered to Carlisle
Big_John
Illegitimi non carborundum
Marcellus, NY
Feedback: 8 / 0 / 0
I'm cleaning out some stuff and rather than trying to sell or ship, I'm going to give it away. Delivery to Carlisle only. I'm not going to ship. All is free.
There probably will be more once I start looking around, so check back.
Just let me know you want it and I will save for you. We'll be there ~afternoon Thursday and leaving ~late afternoon Saturday.
First is a set of electric fans. These are your basic eBay sourced fans. They were on my '70 300 for a month or two and work just fine. The brackets should allow you to bolt them on with no extra holes needing to be drilled. Stainless hardware too. The spots clean off if you are concerned.
Washer pump that I had on my '65 300L. This is the Ford pump that everyone sells as a replacement and requires either an extra hole drilled or if you mount it crooked without the insulators using the stock holes. It works well, I found a more correct replacement (and a bit more $$) for my car.
Formal washer bottle. This needs a little more clean up. Just assume the pump doesn't work.
