Hi Guy's
Ok my 1960 Fury has a 318 poly with a 3 speed auto all standard. When you start the car the starter makes a hell of a noise. The starter has been replaced & the noise is still there. Once it starts there is no noise.
The guy I brought if from said he was told it had the wrong converter in it.
He said he was told it has a converter out of a 61 model are 60, 61 the same converters ?
How many teeth should the ring gear have ?
The one in the car has 176 teeth is this correct ?
It has a starter that has 3 bolts to bolt it on.
The starter is a Auto-Lite #MDU-7001
from what I can find on the net this is the correct starter ?
All help & info greatly appreciated...I need to sort this out to get on the road cruising
Thanks Oz
Thanks Oz
