I'm looking to pep up my 440. I have a aluminum edelbrock intake all ready and a hei distributor . Would like to do a cam swap and throw a fitech throttle body on also and of course headers . Dose anyone have any helpful tips ?
The bottom line here is, what is your budget? It does not sound like you are looking to pull the engine and do a rebuild, but rather want to install add-ons.
All components need to match, so you have to make a plan that works with your budget. The cam selection is what I build around - but it has to match compression, intake/head flow, exhaust flow, and even your trans/rear combo. Select the wrong cam and anything you do could be disappointing.
So first thing would be to look at cam specs and the manufacturers requirements that match the cam. The advantage with the 440 is cubic inches and cubic inches rule. You can build a milder engine that can get the performance of a smaller engine needing to be built bigger, ie more work & expensive parts. Shopping for a cam, I would look more for torque, rather than HP, as torque is what will move all that car.
Once the cam is selected, then choose your intake/carb or the fuel injection system. A carb, in my opinion, would be the easiest and cheapest route to install, versus the EFI which will require an electric fuel pump & wiring. The manufacturer usually sells a complete and matched system that is know to work together. Don't know if there is a specific mounting recommendation for the electric pump, but most get mounted at the rear and often in the tank - but know you can get an external pump as well.
Exhaust is a no brainer. If the car does not have to meet emissions standards due to its age then dual exhaust with nice flowing mufflers. Headers are always aggravation, and for a street car, not really worth it. I'd install what ever size head pipes fit the manifolds and as soon as it makes the curve going back, step the entire system up to 2 1/2" pipe all the way back.
Ignition, as I recall, has the distributor tied into the LeanBurn system. Had one on a 400CI '77 Dodge Monaco Royal. It would act up on me and sometimes not run, then run, then not. Being a young guy, I could not afford to replace the "brain," so I sold it. At the time, doing a conversion was not of interest. If you are not trying to keep it original/stock, I would update the distributor and hang on to the old one to keep with the car if you sell it. I would get a ready to run plug/play unit and be done with it.
I would recommend a higher stall converter. My '73 Fury has the 2bbl 360 and the higher factory 2500 RPM converter. Very peppy when I nail it and I can cruise at 80 MPH all day long with the gearing I have. Gas mileage is not what you are going to get with a 440CI and a heavy car, so don't fool yourself. EFI may help as compared to a carb, but probably not enough to justify the price of it. If you get a converter, you want a "tight" converter vesus a "loose" converter. Installed one in my brother's 360CI SixPack powered car and it does not slip when using easy/part throttle applications, but will zing right up when you nail the gas and his car just takes off - unless he just wants to smoke the tires from a dead stop.
Compression has to do with power, but you do not need high compression to make good power on the street. You can compensate for the lower compression by building up more cylinder pressure with the correct cam choice. Hughes Engines has such a cam called the Whiplash Cam. Click here:
Hughes Engines Listen to a few of the cars with the Whiplash Cam and tell me they don't sound good. Check out the specs, recommended parts, listen to the video clip, and then email Hughes with your "plan." These guys who do this for a living know there stuff and can give you the matching combo you need to build your ride the right way without being disappointed.
Just my opinion.
