challenger
The reman PS pump on my 70 300 is making a lot of noise. It makes a slight wining when going straight but when steering right or left it really makes a racket. In addition to this noise, which I've had before in this car and others, the fluid is milky as if it's been aerated AND the steering wheel pulsating badly unless the fluid is Topped off to a level half way up the neck. At this moment I can't remember which pump it is but I'm pretty sure it's the chrysler/federal /1.06 pump.
Is it possible the fluid got contaminated with water? This car has had a past history of sitting for months without being run? I replaced the pump once several years ago with the current reman unit purchased at Napa. It's been so long ago that I can't remember what the reason was for replacing it.
I'd like to know if it is something I could rebuild myself since the reman units seem to be not so great? I can do about anything automotive but haven't rebuilt a PS pump (yet).
Is the federal pump better for this size vehicle or should I rebuild a Saginaw unit. I have a couple of PS pumps laying around at this point which I can use for rebuilding. Should I just drain and refill this one to see if it is a moisture issue or is the milky fluid possibly from cavitation?
Sorry for the continuous help requests on this car (there will be more
) . I appreciate the help for sure.
