Cadee
1970 Fury with a Rim Blow steering wheel. Had the wheel off to be fixed, put it back on and it wont work.
Ohm meter used and all is good, horn relay is good and the horns themselves work.
There does not seem to be any "wiring" coming up through the steering column to meet up/match up with the "power wire" from the rim blow...damn this is hard to describe.
The two wires, I guess they would be the ground and power wires that come from the rim blow, are new and they have been reconnected to the wheel properly. The only thing coming out from the column is a "spring".
I made sure it comes through the hole in some metal bushing so it matches up with the contact of the "power wire" from the rim blow.
Is this the way the rim blow gets power?
Thank you!
Thank you!
