pgadler
I have had problems with my front right wheel bearings for some time. I hade them swapped at a garage 2 years ago, but during this summer I identified a front end rumble to be a too loose front bearing.
So I adjusted, thinking that the garage had done a poor job.
A week later, same thing. And so on.... The rumble increased and a couple of days ago I dismantled the hub completely.
The outer bearing, outer bearing cup had rotated, grinding a track in the hub. The bearing cup was loose by at least 1 mm. The grinding had been lubed by the grease, so the surfaces were smooth almost leading me to believe that the track/groove was "as designed". But no way that the hub could be kept in place with the outer bearing cup wobbling about.
So, the school book approach would have been to have the hub milled to oversize and sleeved it. But I am to impatient for this. Since I have original Budd disc brakes, a used good hub is "unobtainable" here in Sweden.
So I cut a piece of sheet metal, smothed the edges, and formed it to fit in the track/groove. Lucky me, it was easy to make good fit. And the track/groove was just the right depth, so that a 0,75 mm sheet metal would give just the right diameter, even a bit tighter, than original hub diameter.
Now all is assembled and no longer that terrible bearing rumble.
