Knebel
So, i have a new starter installed because i had an issue that when the car is hot and sits for a while to heatsoak, the starter wouldnt turn the engine. It would just....turn a little and then stop but not disengage.
Installed a new mini starter, everything fine for a while, cold crank, hot crank, like nothing.
Now the problem is back. I havem measured the charging system back and forth and do get almost 14volts on the battery. My ammeter also shows positive when driving and just pegs around a bit at idle.
Now, i started the car cold, no problemo, drove 5miles, waited 20minutes, wanted to restart, nothing. Starter engages but turns only a tiny bit and then stops. Tried it 2, 3 times and then it started klicking like a dead battery. I have a battery jumper pack which i conne ted and the car instantly started. No problem whatsoever. Then i drove another 5miles home. Parked and tried restarting instantly. Nothing, starter engages, turns 1/4 turn and then wont move. Try it 2 times and it klicks like a dead battery. I measured the battery and it was 11.88vokt between the posts.
Is that my battery being dead? Or is my brand new starter toast? I cant imagine its not charging the battery but you never know. Everything indicates its charging just fine.
