For Sale Transmission crossmember 1969 – 1973 Chrysler full-size C – body
1970FuryConv
Richmond, VA
I removed this transmission crossmember from 1970 Plymouth Sport Fury. It was equipped with 727 automatic transmission and 383 V8. However, this transmission crossmember will work for any C-body, 1969 through 1973. The crossmember is clean and straight. You can run degreaser over it to remove any remaining surface grease, prime and paint chassis black, then install. No rust holes. I do not know if it will work on 1965 through 1968, but I believe since the car it was removed from had the same front subframe as at least 1966 through 1969, it will work on earlier years of Chrysler full-size C body. Plymouth Fury, Dodge Polara/Monaco, Chrysler Newport/New Yorker. 1969, 1970, 1971, 1972, 1973. $50 plus ship. Location: King William County, Virginia.
