Pclancy
Gentlemen:
My 77 Newport came with an AM only radio/tape deck. I decided that I wanted an FM band also and because I wanted to keep the car with original equipment I....
Bought a used AM/FM stereo radio tape deck from Murray's (the model pictured on page 11 of the 1977 Chrysler sales brochure) and then had it restored by Joe's classic car radio.
Question one: Regarding the removal of the original radio/tape deck, are there any tricks or lessons learned here? I have a service manual. I assume that the instrument panel bezel needs to be removed. Anything to watch out for? I assume the dah cover does not need to be removed?
My vehicle has 4 speakers--two under the dash and two in the rear shelf. I believe these to be the original speakers. For the rear shelf, I think the size is approx 5X7". While I can only see the rear deck speakers (by crawling around in the trunk), they are marked "Deluxe" and they have a bunch of numbers on the magnet plus what I think is a Chrysler symbol.
Question two: Does anyone know if these are 8 or 4 OHM speakers? They use a common ground system--that is, one wire only leading to the positive terminal. The thought occurred to me to replace these as well, but I am unsure of which ones to buy if I do that. Since I would be using the original stereo amp, which is very low powered and common grounded, sourcing correct replacement speakers is not at all easy. The current speakers sound ok-good, and look in very good condition and so part of me says leave it alone. The other part of me says they are probably almost 40 years old.....
Finally, my original clock (with minute and second hands) ticks but does not keep time. Again, I went to Murray's and bought an electronic digital clock/chronometer (the one pictured on page 10 of the 1977 Chrysler sales brochure). This is now being restored. I figured that while I was replacing the radio, I would replace the clock as well.
Question three: Is the wiring different? Any tricks or lessons learned here?
Thanks tons folks for all your help!
