Vacuum hose connection
polarus
I have a vacuum hose on my 72 Polara 440 with A/C, it runs from heater control out through the firewall to the engine compartment, it runs along side the cable for the water control valve. Anyone know where it ties in? Service manual just says "go's to engine vacuum." Should there be a port on the intake manifold? I'm trying to keep it as close to factory as possible. Thanks.
As a side note, what about the carb bowl vent line and the vac and purge lines on the carbon cannister?
Somewhere, in the FSM, I suspect there are vac hose routing illustrations for both the HVAC system and the emissions system too.
Typically, the vac source for the HVAC system is a vac tree on one of the rear intake manifold runners or a fitting on the power brake booster's main vac line, at the booster. In some cases, there might be a separate vac reservoir under the hood, where the HVAC vac goes first, before the vac goes to the control units. That additional reservoir can also have a check valve in it to prevent the a/c air from coming out of the floor and defroster vents during long periods of heavy throttle and lowered intake manifold vacuum.
It's a little confusing because you are showing the cannister for the evaporation system.
The green striped hose should plug into the vacuum port on the intake manifold that the power brake booster hose is attached to. It will look something like this:
It may have more or less spots for hoses to attach to. These are sometimes lost or discarded with engine swaps or rebuilds, so you may not have the correct vacuum fitting on the manifold.
You're right Big_John, I was just trying to show the overall length of the hose, it's too small to fit on any of the ports on the canister which is evap. only as far as I know. Looks like I need to purchase a new fitting for my intake manifold. This is the only reference I could find in the FSM.
I am most certain that the hose goes to a vacuum reservoir. It’s not shown in the diagram of the interior.
You're right Big_John, I was just trying to show the overall length of the hose, it's too small to fit on any of the ports on the canister which is evap. only as far as I know. Looks like I need to purchase a new fitting for my intake manifold. This is the only reference I could find in the FSM.View attachment 553570
See scrawling
That would be true IF there was a vacuum reservoir.
I double checked a '72 FSM and the only mention of a vacuum reservoir is in the Auto-Temp A/C system.
I double checked the 72 parts catalog and it shows vacuum reservoir for ATC cars only, but it seems strange not to have vacuum canister, I was sure that's why the vacuum hose was so long.
