Edison
I was reading about different things today and came across some folks running ventilated drums on their classic cars rather than swapping to discs.
I have long heard that drums offer the same quality stopping power as discs with less weight, but that due to heat getting trapped in the drum that causes brake fade. And eventually as people drove more and more, and cities became more populated and heavy braking was required, manufactures started using discs (since a disc is exposed to air, it cools faster).
But then I started reading about folks who had professionally drilled drums as to allow dust and heat to escape. Has anyone here ever had that done, or have any opinion on it?
EDIT
Wanted to clarify that I am not debating which is better, drum vs disc, but just if anyone had considered the ventilation as a low tech, inexpensive way to "improve" their existing four wheel drums.
EDIT
