What is the correct pickup for the 933?
tallhair
Rufus T. Firefly
Staff member
Mascoutah, Illinois
What is the correct pickup for the 933 and similar oil pans?
Bent or straight?
Your expertise is appreciated
Cheers,
Bryan
Straight tube is for a pan without baffling.
The tube with the extra bend is for a baffled pan. It can also be used in a non-baffled pan. Baffled pans were for HP engines.
Thanks much !
Were the same pickups used on the similar C body pans with different numbers that I can’t recall right now?
Thanks much !
I don’t see why you couldn’t. I’ve swapped around the pick up on 187 and 699 pans, but not on a 933. Not sure about that one.
