mdh157
I am changing the carb on my Ambassador and trying to figure out where I can hook the elec choke wire up to. My problem is that there does not seem to be an open port on the fuse panel where there is power only when ignition switch is 'on'. The car has been converted to an elec fuel pump that is already wired in to what seems to be the only port that would have worked.
Any ideas? I want to avoid hooking it up to the coil or other place where it is technically not correct. There is a open port that says “spot” but I have no idea what that is. These were not avail with spotlights afaik so I don’t think it is that. Plus that would likely be a power all the time port anyway.
