Window Tint
65sporty
Kingston, Mi
Anyone try to tint their own windows? I did the rear windows on my son's cutlass ciera , the side windows weren't too bad but the rear window was a nightmare. Never did get all the air bubbles out. The pro's make it look easy.
I jut did the '78 New Yorker Coupe rear window with removable tint. The process is the same as premanant tint. It sits fine even at 75 mph. To help out you can cut and trim it on the outside and if you want then remove and put on the inside. Use Baby Shampoo/water mix, a good squeege and a sharp exacto knife.
