SOLD 1966 Plymouth Fury III
11secondC
Grand Rapids, MI
1966 Plymouth Fury III - Curious Yellow E85 - $8,000 obo. No trades. Grand Rapids MI.
'70 440 0.030" overbore, block was decked, linehoned, ARP bolts throughout. SRP pistons 11:1, steel crank 10/10. Moroso 7 qt oil pan. 200 psi cranking pressure.
Edelbrock Victor intake, 850 DP E85 Holley by Horsepower Innovations.
Hedman 1 3/4" B/E headers, 3" exhaust with H pipe.
Crane HI-6 ignition box/coil. Locked out MP distributor.
Fresh Edelbrock RPM heads, Comp Cams hardware, 928 springs, 10 deg locks.
New Howards Cams, mechanical solid 722362, 0.550/0.555" lift, 254/260 duration, 108 centerline, Howards Cams Direct Lube solid lifters.
Crane Ductile adj rockers, MP hardened shafts.
727 - 9.5" PTC converter, deep pan, Keolene steels, Red clutches, Turbo Action forward pattern manual valve body.
8 3/4" - Detroit Locker with 4.10's, Moser axles.
Front susp: 318 torsion bars, Lakewood 90/10 Drag shocks, '73 manual disc brake conversion. Manual steering, aluminum steering box. Goodyear 215/70 radials, 15x7" Weld Draglite.
Rear susp: Caltracs with Monoleafs. 2" lowering blocks. Rancho 9000 adjustable shocks. 28 x 11.5" ET Streets on 15x8" Weld Draglites. Frame has been tied with 2 x 2" sqaure tubing.
Fuel system: 16 gal fuel cell, Holley Black fuel pump, 1/2" alum line, Mallory reg.
Cooling system: Aluminum 28" 2 core radiator, MP aluminum waterpump/housing, aux trans cooler, electric fan.
Interior: Factory bucket seats, Auto Meter Sportcomp gauges. B&M Megashifter. Radio delete plate, heater box/core removed. Rear firewall installed.
Pictures:
https://www.facebook.com/dana.dowhan/med...amp;pnref=story
Sounds too good to be true,,,,,couldn't see pics of the car on FB just pics of you.
Sorry guys, didn't realize not everyone has Facebook, link should take you there. Here's a couple, email me and I can shoot you a bunch more.
Reply to some questions, yes I have a back seat for it, will need to be recovered. I do not have the skirts. Original 318 poly car, Turqoise. Rear bumper was rechromed 2004, front grill/bumper/side chrome is original. I put the VIP taillights and Emblem on the car.
I believe there are some vids on you tube of this car running at the strip?? If so, the car runs strong! Really nice car for the money, good luck
