WANTED 1967 Chrysler clear side marker lights
Camshaft
British Columbia
Would anyone have any idea on who I might get one of these from? Tried a lot of the usual suspects but no luck. Part #2606776 Right side. Even if I could find the wire and socket, I could probably rig something up but entire piece would be great. My lense is good, but mounting flanges are broken. Final question: does anyone make gaskets for this stuff anymore? Or do I just make my own? Appreciate any thoughts. C shaft.
That would be a cornering lamp. Side marker lights came in ‘68. That lamp only comes on with the corresponding turn signal illuminating the direction you are turning. Not sure how popular an option that was back then or how many are still around today that are salvageable. Murray Park in Tiffin Ohio would be a good source to check.
I am going to guess at what you have as you didn't bother to tell us............
a 67 Newport or 300????
if I am correct the you need.........
2606772 R lamp
2606773 L
2808984 R lens
2808985 L
is that # you posted the casting #?
Am I close?
Sorry my mistake, 67 Chrysler 300 convertible. The number on the back of the right lamp enclosure is 2606776 and the left side is 2606777. Neither of these could I find in the 1967 parts catalogue, but that is what they have stamped on them, in addition to the pentastar and 67. Cam
Casting numbers on parts do not always equate to actual part numbers. Some might be close, others not so close.
Marty: you are one of the experts on parts obviously, given your background and business, but this light has the following numbers on it:
2606776 AALG 1 32282 on the top lip, the letter R on the back, and SAE K 67 CL and the pentastar on the bottom lip. I assumed that the 7 digit number was the part number as it was so close the 7 digit number found in the 1967 Parts catalogue. I can find no other vehicle they may have come from, perhaps they were replaced long ago. The bigger, and more important question is: Do you have any? Or know of a source? Much appreciated, Cam shaft
I have the lenses NOS in the boxes if interested. I am away from home for medical treatments and will be glad to send pics when I get home approx. 5/7/21
