WANTED 1968 fury odds and ends
Shakerdave
Middle
Needed good condition:
Radio antenna, sill plates, heater control, center trunk panel mounting clips. Shipping to 53511.
Thanks, Dave.
Thanks, Dave.
I have a bunch of 68 Fury parts but I’ve already sold everything you have on your list. If you think of anything else PM me. I may have an antenna from a different C body also
Thanks, Dave.
Murray Park has reproduction sill plates.
Do you need an entire antenna assembly or just the mast? FYI if you need the mounting bezel a '68-'69 Barracuda antenna bezel is almost the same and works and looks just fine.
I may have an NOS heater control unit SOMEWHERE. I moved a year and a half ago and have no idea what box it may be in.
If you still have the trunk mounting panel clips but the thin tabs that slide into the trunk finish panel are broken off (as they usually are) try pop riveting a thin piece of steel or aluminum of even an old credit card to your clips to get the clips to be long enough to slide into the finish panel.
Thanks, I'll give the cuda antenna a try. PM me on the heater control if you find it.
