stu’s68furyiiirat
I need to upgrade the starter it’s a La 318 5.2 I heard of people putting mini starters on them I think right like 90-97 Dakota starter right any help would be great thanks In advance I’m still learning
when installing mini-starter on my 72 Fury LA blockWhere can I get the terminal adapter kit
You could probably rebuild the old one....The old one is bad is why I am willing to upgrade to mini starter
Even if not high compression, the mini-starter is a better piece.What´s really the reason of using a newer style starter? If your engine is high compression or the old one is broken I could understand but my original one works fine and I can´t see an advantage of a new one. Car is starting well.
Yea, but it doesn't sound like a Chrysler starter...Even if not high compression, the mini-starter is a better piece.
Spins the engine faster and uses less amperage to do it (I believe).
So when conditions turn against you (cold outside, battery a little weak, etc) a ministarter will get the engine running where a big-boy might not be able get the job done.
EXACTLY!Yea, but it doesn't sound like a Chrysler starter...
Yes, but I got over that when the sound of a Chrysler starter signified to my neighbors I was trying to get my car started.Yea, but it doesn't sound like a Chrysler starter...
My junk always starts, so I guess I have both worlds.I love the tar-aarrr-aarrr sound. But I like the 'modern' sound of a fast-starting engine better.
