1973 Disk brake conversion on a 1965 Fury
Howard Willey
Newcastle CA
Hi I was wondering if anyone had pictures of how they ran their brake lines on a 1965 with 1973 disk brakes. Did you use custom lines? Or is there a part number that works?
The easiest way is to scavenge the tubing from a donor car. That is usually pretty much a bolt on. You will need the distribution block and the tubing from the master cylinder to the distribution block.
I was talking about the rubber brake line from the front of the frame rail to the caliper. I’d love to see a picture of anyone with a 1965 that has done this. I believe 66 and later they moved the fitting to the back side of the tire on the frame rail.
If I recall correctly, I got everything for my conversion from a 73 Monaco (?), it was a full size Dodge, at any rate and I believe I used hoses from the 73 (but new replacement, of course). I will need to see if I can find my notes. I did my conversion back in the 80's - before internet. (Really-not kidding)
