NOT MINE 1973 Plymouth Fury III 4dr Hardtop - $4,000 - Brownwood, Texas
T-revorNobody
Sidewinder, Colorado
At the time of posting, this FB ad is 6 hours old.
FB Description
1973 Plymouth Fury 3 · 4 door hard top. · Driven 92,000 miles. $4000.00 Nice 2 owner Plymouth Fury in Metallic Tahitian Brown. 92,000 original miles. Has the deluxe interior with fold down arm rest. Original 360 2 barrel carburetor. Runs nice. All hoses, gaskets including intake gasket was replaced. Carburetor has been rebuilt and functions like it's supposed to. 3 speed torque flight shifts smooth and crisp. New shocks, sway bar links, ignition coil, ignition control module, alternator, power steering hoses, timing chain, water pump, thermostat, transmission mount, fuel pump, brakes including hub rotors with new bearings. New fuel tank with new sending unit also. All gauges work. New true dual exhaust system. New Goodyear tires. Car is super smooth cruising down the highway and starts up smooth everytime. All fluids are new. Good compression and oil pressure in engine. Located in Brownwood Texas. [hidden information].
Assuming there is no rust and the work was done well, this car should be a great entry point into c-body ownership.
Appears to have a non cracked dash! Good deal although I'd lose the white letter tires.
While the dash does look nice at first glance, I think I am seeing a crack at the top center of dash.
Certainly agree on needing white walls, especially on a Special with the upgraded interior and deep pile carpets
Mine originally looked like this. It's in very rough shape now, but still all original with only 60k on the dash. Needs a top, a dash, and some other things. Tore the headliner out of it, she's pretty hurt, but still love it. The interior is exactly the same, so I reckon this is the same trim.
4592_n.jpg?_nc_cat=100&ccb=1-5&_nc_sid=e3f864&_nc_ohc=3wdP1SeOUMEAX_JQFhn&_nc_ht=scontent-ort2-2.jpg
For records, this KT9 Fury with A82 Gold Sticker Special package is PH43K3D296043
