1977 NYB Cruise Control
Russell Petry
Pleasant Hill, Missouri
I have the complete cruise control and it worked a little for a few rides after I get the car in 2021. I say it worked a little bit because it tried to keep the speed where I set it but ended up not. I pulled a vacuum on the diaphragm on the cruise and it is definitely leaking in the diaphragm. Question is are the diaphragms still available somewhere? I would love to have it working if that is all that is wrong with it. Thanks in advance!
If you can pinpoint the leak on the diaphragm, I've had some luck with a bicycle tire repair kit
My "source" makes them new in reproduction, but he's currently without a shop facility, and I don't know when he'll be back in business.
My cruise was not holding vacuum, so I opened it. Diaphragm was in good shape. I think it was a mechanical/ electrical problem. There is reed valve on the vacuum inlet hose of the servo, I think it gets stuck open keeping servo from holding vacuum.
More likely to be a problem with your vacuum dump valve. The reed valve you mention is only to open and close the source of vacuum to the chamber. If your diaphragm is good you should check the o-ring underneath your dump valve and also the gasket on the side where speedo cable is mounted. If those check out you'd have to benchtest the dump valve. Could also be an issue with your brake switch though
Edit: same goes for the OP of course, there are several places for vacuum to leak in these things
Good Afternoon
A member on the Dry Dock forum reproduces them.
Got one last fall. Haven't used it yet since the 'Barge' is still in dry dock.
ZOL Products
Omni
That's my guy - he used to be here under the name Kurazy Joe - but he had some issues with where he lived and he went dark. I'm glad to hear that he's up and at them again.
Okay... I found this guy last year and send him email about 3 months ago, but didnt get any messages back so i thought that his not making those anymore.
Maybe i try to contact him now or something.
If you are talking about Kurazy Joe, I sent a PM through the Dry Dock site. He responded almost immediately.
Omni
Diaphragm is already on its way to Finland!
Joe responded to me and when i bought one, he send it immeaditely to me.
