2000 HP 2.2 4 cyl
300rag
Cochrane, Alberta, Canada
Put this in that little econobox @commando1
https://www.enginelabs.com/news/mazworx-2000-horspewer-billet-sr20-secures-the-4-cylinder-record/
The last time on the dyno, the badass SR20 made just north of 2,000 horsepower at 11,200 RPM. “We made 2,010hp the last time at the dyno,” Soler shares. “As you can see on the dyno sheet, the engine picks up almost 800 horsepower from 8,600 to 8,700 rpm.” That incredible power jump is due to the inherent challenges of spooling an 88mm turbocharger with only 2.2 liters of engine displacement.
It's amazing how much power they can squeeze out of an engine now days, especially the stock factory stuff making ridiculous power 4, 6, and 8 cylinder.
Sure..... but how many times do you think they can spool it up to 11,200 rpm's for 2 seconds before it grenades????
If it came apart at those kind of RPMs, there would be a lot of shrapnel holes in everything, probably including the driver. Hopefully there is lots of Kevlar around the installation.
With all the custom parts it has it should be able to turn some RPM's, the only thing factory Nissan is the head casting.
