68PK21 440.6bbl
Yea but he said "It starts fine several times around town." and "One time, I managed to crawl under the car and screwdriver the starter selenoid and then I turned the ignition key and the car started and continued to start for another 12 starts or so."While that is the usual problem with the starters, and I have changed them, since he "jumped" the contacts on the starter, which engages the solenoid that drives the drive gear into the ring gear AND makes the contact that turns the starter (with the contact above), he actually proved that was OK and working properly.
If he jumped the contacts on the starter and it DIDN'T work, yep, that's probably the culprit.
He also mentioned smacking the starter which is a big no no. Especially a 50 year old starter.
OEM NOS parts for the reduction motor are still available, although a bit pricey especially if they have the word 'CUDA' in the description.
If and a big IF you have/find that you have a survivor starter motor that hasn't been through a re-builder/remanufacturers grinding, undercutting of the commutator, and that is one of the biggest problems I found all across the board with remanufactured starters is the heavy hand with cutting the commutator. Chrysler has a spec you can measure and if it is too small of a diameter and the length and strength(?) electrical charges in the winding's reducing the horsepower of the starter. And I've even looked at remans that I replaced with new starters very closely at where the armature winding's are soldered to the commutator and found broken solder joints on fairy recently installed remans (kickback).
Have pride in your skill & work with a known rebuild with NOS parts, rather than getting stuck somewhere with a crap reman.
Now of course if you have a bored & stroker, lumpy lumpy cam, headers etc. maybe go with the mini starter, but I'll tell ya many many built Hemi's back in the day still used the reduction starter, It's a very good unit.
