39 Plymouth, cooler than a SBC
300rag
Cochrane, Alberta, Canada
This Airplane-Engine 1939 Plymouth Pickup is Radically Radial
AAhLq7m.img
AAhLAR2.img
AAhLuX3.img
That thing is mean, did you see what looks like a quick change diff in front of the engine with the drive shaft laying there? He must be running a belt or chain down to it. A friend of mine talked about a similar idea but on a smaller scale, his would have to be a custom engine. He is always coming to me with new idea's and some are crazy but here I see someone thought the same thing and executed it rather well.
I looked at the pic's again, looks like a gilmer blower belt running down in the last pic.
That is a really cool truck. Imaginative and well done it seems. :)
Technical question for anyone who knows. .. why all the smoke? Comes with the territory for radial engines of this vintage or just for show?
Being an airplane guy, I hope and I'm sure he knows how to take care of a radial engine. The bottom 3 cylinders, that is the ones at 5,6, and 7 o'clock can fill up with oil from the crank case MUST be drained or turned over manually to get the oil out. Most aircraft with these engines have a sump system to help keep the oil from filling up the cylinders. If not they can hydro lock. As cool as radial engine are, they are a huge pain in the *** to own and maintain, and I take my hat off to those that do.
I've read up on that before ... can be pretty catastrophic if you attempt to start it with them full
Hydro-lock bad
Brings up the question of how do they start it if they can't pull it through without a prop and those are not really no load idle engines due to poor oil control at high vacuum levels.
