Tony Mopar
Hiya guys,
Planning to drop a fresh overhauled 440/727 trans in my 360/904 Fury. Already solved alot of issues but there are 2 things that I need more info on:
I read alot about the Schumacher mounts to do the swap, but surfing the web I stumbled on these from 440Source:
Engine mount - New
Used on B bodies from 1966-72, C bodies from 1966-73 and E bodies from 1970-74 Use 2 per car.
In Stock
and
Engine Support Brackets 66-72B 66-73C 70-74E
Shown above are our most popular brackets, Chrysler # 2536132, for the right side, and 2863751 for the left. Notice the left hand bracket will have a tube welded across the channel area of the mount (shown above on the right) making it easy to distinguish from the right side bracket. These were used on B bodies from 1966-72, C bodies from 1966-73 and E bodies from 1970-74. The right hand bracket (2536132) was also used on the passenger side of big block A bodies from 1967-69 with our 101-1063 insulator. Great replacement brackets for missing or damaged originals on factory big block cars, or for transplanting a big block into a small block car (except A-body) of the above years and body styles. No k member changes are required. Use with our 101-1063 insulators. These are sold as a set including one right hand bracket and one left hand bracket.
In Stock
I sended out an email to 440source for these items and they told me that I need these 2 for my swap as they are the original brackets for a 1972 C-Body Bigblock car. If so, why is everyone going for the Schumachers then?
Need some advice to make the right choices here
Engine mount - New
In Stock
and
In Stock
