60 Dart Steering Box
Kapt
Northern CA
It's a V8 power steering car. Will anything more modern fit on a 60? I'd like to upgrade both the box and the steering column if anything newer will fit the car and able to change with the engine installed
My advice would be to have Firm-Feel or another quality supplier service and upgrade your existing unit. You are sure to have a gear and column that fits that way. Mopar used similar mounting systems for the steering gears for a lot of years, but the gears that were used in that time were not very much different in terms of performance and reliability.
Most "modern" steering systems use a rack and pinion system that probably could be adapted by a specialty suspension/steering shop, but you are going to be into some serious bucks to get that done.
O.K.
Long & Possibly Boring Rant to Follow.
Many Years Ago I had a 1959 Dodge Custom Royale.
Wanted to Convert to 69 Plymouth Fury P/Steer.
Had a Fella with a 59 Plymouth Fury who Also wanted similar.
He was a Truck Chassis Modifier / Designer.
The Chassis in My 59 was 80 Cm (Approx 31.5 Inches) between the Rails, the Sub Frame in the 69 was 81 Cm between the Rails. (Approx 31.75 ? Inches)
Obviously Very Close.
I Supplied a Complete Set of P/Steer in Exchange for Him Doing My Chassis when He had Finished his Own.
He managed to Do the Conversion & was Very Happy with the Result.
Sadly He Passed away before he could Convert My Car.
But as I remember it was a Matter of Mainly Notching the Chassis to Accept the Later Model Box. I Assume Copying from the 69 Sub Frame Design.
(Please Remember we are Talking R.H.D., Compared to L.H.D., The P/S Box Sits In an Entirely Different Location on the Chassis Rail, Not Just Mirror Imaged.)
Please take Note. Modifying a Chassis is Definitely NOT a Job for the Average Competent Welder, He has to Know & be Experienced in Chassis Welding / Modifying.
Having said that, I do Feel that it is Not That Big a Job if You Know What Your are Doing. Just Not a Job for a Backyard Welder. Even an Experienced One.
In Regard to Rack & Pinion, Although I know of a Number of "A" Body Conversions that are "Apparently" Successful, (Mainly for 383 / 440 BB Conversions)
I also know of a Couple of "C" Body Fellas who Converted to Power R&P and were Really NOT Satisfied with the Result. (Super Wide Turning Circle, Heavy Handling Etc.)
Now I Need to Put a Qualifier on My Remarks.
This was 25 Years Ago & here in OZ. We Just Did / Do Not have the Variety of Resources or Technology that is Available in the States.
(You Fellas have a Far Wider Range of Vehicles to Choose From)
I will leave it up to your Fellow Americans to Best Advise You.
Just Hoping these Comments May Prove Helpful / Informative!
Kind Regards. Tony.M
Here's what I'm wanting to do, and why I'm asking. I want to add a tilt column in my Dart. From what I've come to understand this is no easy task with the 60 box. That's why I'm asking if something from a newer car will cross over and fit
Well, the best answer I can give you us, "Why not?" lol. My column is pretty wore out. The threads for the wheel nut are about shot, and it's almost impossible to find a wheel adapter for the 60 since they were only made for one year and have long been discontinued. I have an aftermarket steering wheel now, but it's not right. Changing everything over will resolve an issue or two, and give me a new option I don't have now. Then there's the "Why not?" and adding tilt
I build complete ("everything you would need to convert") Power Steering Conversion kits for:
1955 and 1956 Dodge and Plymouth
1957 thru 1961 Chrysler, Imperial, Desoto, Dodge and Plymouth.
If interested give me a call or Email
Floyd Richard Sr.
YouTurn Power Steering Conversions
Santa Fe,Texas
409-789-4064
Email-- floydyouturn@hotmail.com
