65 fury iii 2dr ht interchange?
MyDads65Fury
Lancaster SC
I need quarters and some other stuff. is there anywhere online to check interchange, or is it best just to get word of mouth.
I found a running, driving, 66 fury, not sure of trim level but it is a 2d. Will those quarters work? Hood? Decklid? Trunk floor and rear body panel? Bumpers?
Thanks
The 66 is just a little different on the back corners behind the bumper surround. I bought some 66s and only used the very bottom of the panel.
Depending how bad your quarters are, you might be able to do the same.Try to find a solid parts car, the repop stuff from the guy in Canada are supposed to be garbage. I talked to him on the phone and his attitude was really bad.
I wouldn't give him a dime on that principle alone.
Yea, the bottoms of my quarters are somewhere back in the 70s.. Id need right behind the bumper but im sure someone can make that work, right.
I can see the decklid is different, how about the hood?
Quarter innerstructure? and rear trnk floor?
The hoods are the same and the trunk floors are the same. I would imagine that the structure is the same until you get to the tail panel areas.
Maybe its just me but the lower body line looks more pronounced on the 66.... And, no gas door lol. Which that wouldnt matter if im only using lower, but just pointing it out
