67 power steering pump
Doak
Hamilton Ontario Canada
just had my TRW pump re built. worked fine for about 2 hours then lost power steering. I have had nothing but problems with it. Any thoughts? Also can I upgrade to a newer (like 68/69) Saginaw pump? 383 bb
Cheers
You can swap to the Saginaw but you will need the correct brackets and you may want to check on the pulley's to see if they are different.
