Mar 1, 2025 #1 I ike61 New Member Joined Dec 6, 2010 Messages 31 Reaction score 12 Howdy all. I have a 68 fury 1 2 door sedan. Does anybody know if I can remove the oil pan without jacking up the motor? It's a slant 6. Thanks
Mar 1, 2025 #2 Big_John Illegitimi non carborundum FCBO Gold Member Joined May 21, 2013 Messages 24,958 Reaction score 39,899 Location Marcellus, NY ike61 said: Howdy all. I have a 68 fury 1 2 door sedan. Does anybody know if I can remove the oil pan without jacking up the motor? It's a slant 6. Thanks Click to expand... Best thing to do is download a factory service manual at Service Manuals – MyMopar Once you do that, turn to page 9-21 and the procedure is right there. The short answer is there is no need to jack the engine, although you may need to turn the crank so the pan clears as you pull it out.
Mar 1, 2025 #3 I ike61 New Member Joined Dec 6, 2010 Messages 31 Reaction score 12 Holy crap. That was quick. Thanks!
Mar 2, 2025 #4 3175375 Old Man with a Hat Joined May 16, 2018 Messages 5,963 Reaction score 10,772 Location Centerville, South Dakota Do what @Big_John referenced. My bet is that you can do this without removing the engine. You will likely have to jack it up off the motor mounts, but you can do it.
Mar 2, 2025 #5 Blusmbl Active Member Joined Dec 17, 2022 Messages 233 Reaction score 258 Location Plymouth, MI Big blocks you have to jack the motor up a couple inches to get the pan off, but it’s really not a bad job either.
