Bob Burgess
Hi Guys,
I am trying to locate the plastic clips that hold the rocker panel stainless on ( these ones are white plastic ). each clip is 3 änd an 1/8 inches long x 1 and 1/4 inches wide. There are two studs welded to the rocker and you slip the top part of the clip on to the top stud and the slide the bottom of the clip sideways to lock it on. Then you simply push the trim on and it snaps in place. Have searched every where and can only find the ones with a centre bolt but prefer not to drill holes in the rocker.
