I'm gently reviving a 69 300 and it's responding well. That said, the brakes are hard to press when moving the car around the driveway and in and out of the garage (no dragging, grinding or other weirdness, just needs a real hard press) and I need to get this sorted before I do anything more. The car has drums front and back and has a power booster. I've been reading about the booster and check valve and I have a couple questions;
The car is very stock, like crazy un-touched, but I see the booster valve has a second port on it with no hose. I realize this would impact the function of the booster so I'm interested in plumbing this second port before I do anything else. Where should this port route to?
If I were to remove the check valve from the booster, how would I do that? Just pull on it? I figured I'd ask in case there was a trick beyond a serious tug.
Thanks!
Thanks!
