Andymac1985
Hey all, first post here so i'm hoping someone can help.
Ive recently bought a 66 Dodge Phoenix with 440 and 727 in it, with a b&m pro ratchet shifter. The shifter cable needed replacing so i'm in the process, i've run into a couple of problems.
Everything lines up as it should, but it wont select neutral when comming from park, but selects fine when moving up from 1st? Sound like a shifter or transmission problem?
The other thing i found odd is when under the car moving the selector manually, it feels like ive got some sort of a half gear in between park and reverse. Is that normal?
Cheers from down in Australia, Andy
