Daniel Romero
What is a good Edelbrock, Holley or other two barrel carb model to upgrade to for a stock 400 in a 1973 Fury?
When you say " upgrade",,, what is it you are looking to do?
What are you hoping for,,? Expecting...?
The Holley 4412C is rated at 500cfm and comes in a manual choke version only. This is designed as a universal replacement carb, mostly for performance applications.
The Holly 2300 is rated at 350-500 CFM is also a manual choke version only. Also a universal replacement.
I don't know if the air cleaner and base plate for these carbs are going to fit your application. You could have had a Holley 2BBL as standard equipment but the car also may have come with a Carter BBD.
You might want to also consider a stock 4BBL manifold to which an aftermarket thermoquad could be installed. That would entail a lot more work.
The after market Holley carbs are in the $400 range, so you might want to consider rebuilding what you have.
Thanks for the recommendations. I may just end up having it rebuilt. It’s a holley that’s in it now. I’m not sure what model but it looks original.
