ANOTHER STUPID IDEA ?
69PHOENIX
Mystical Land of OZ
Greetings People!
Been Thinking, (Not Always a Good Idea)
Would an ODDS & BODS Page be of Any use?
Details Small & Large that might be of use to People.
I worked in the Wrecking Industry for many Years & I knew a Fella with a Photographic Memory.
He could tell you the Interchange of a Range of Parts & Models spreading over 30 odd Years. Just thinking that among us we would have a Vast Wealth of Knowledge. Sharing could be Somewhat Helpful.
My two cents worth: Many Years ago I was trying to convert a 1959 Custom Royal to Disc Brakes. I found that the Disc Brake from a 1969 Plymouth Fury had the same Bearing Sizes & Spacing on the Spindle as the Custom Royal. After that it would only have been a matter of designing a Caliper mount. I ended up dropping the idea when I managed to procure a set of 73 Dodge Monaco Discs & Spindles. The trick there was to have a Local Machine Shop turn up a set of Tapered sleeves to adapt the Monaco Stubs to the Custom Royal Ball Joints.
A Further two cents: From 1965 to 1972 in the Land of OZ The Spring Perches were All the same Spread so it's possible to fit Wider Wheels by Swapping Diff Assemblies.
Anyway What do you Fellas Think. Tony.M
