I have not attempted to lower the top yet but would like to do so. It probably has not been operated in about four years. Is there anything I need to watch out for or lubricate before seeing if it will work? Also, what is the zipper for in the attached photo and does it need to be undone before trying to lower the top? Finally, how high does the top get during closure? I'm not sure if there is room in the garage or not.
I would also like to remove the rear seat. I recall on my Barracuda that the back lifted straight up and out and I think you pushed the bottom towards the trunk a bit and then it would lift out. Is it the same for the Fury? It looks like it might be a little different for the convertible.
Thanks!
Thanks!
