GoneLoco99
I am using a 68+ 727 transmission with the 3 peg NSS/Reverse lights.
I installed a Cheetah Turbo Action floor shifter and I’m not using the factory column shifter. Working on a 68 Imperial.
I ran the MIDDLE peg on the switch/NSS to the negative side of my starter relay and that is working.
I unhooked the 2 purple wires on the factory “back up light” switch at the bottom of the steering column and wired those 2 purple wires to the 2 out side NSS pegs on the transmission. Put transmission in reverse on the backup lights are not working. Would anyone know why? I also checked the fuses too.
Thank you
Thank you
