66SportFury
Hey guys! Is there a brighter bulb that can be installed for dash lights? Maybe LED's??
There's different wattages of the same size bulbs available.
QUOTE]
That is a good point. I bought my LED's off ebay where they were advertized as direct replacements for existing dash bulbs, (T10, I think).
I just assumed, (theres that troublesome word again), that they would be brighter.
Gotta remember that a brighter bulb creates more heat, and that could be a problem in a confinded area like a dash.
If you haven't checked already, its worth the trouble to check the voltage coming from your dimmer/headlight switch. My dash was very dim, and during the troubleshooting process I was testing the voltage at the bulb socket and found it to be only ~9.6 volts with the dimmer turned all the way up (or down if you're a glass half empty kind of guy). After further inspection, the voltage drop was due to 50 years of corrosion and wear on the rheostat of the switch. Long story short, replaced switch assembly and saw a drastic improvement (although definitely not bright by modern standards).
I replaced all the dash bulbs with LED's in Jazebelle when I had the dash apart. I'm sorry I did now. Incandesent bulbs give off a brighter "glow". The LEDs seem to be a more direct light pattern and appear dimmer.
I went back and changed the ones I could easily access.
I was thinking about going with something like this:
http://www.ebay.com/itm/Chevy-White...ries&hash=item3f24bab5ef&vxp=mtr#ht_884wt_918
They appear to have an omnidirectional thing going for them, is this the type you used??
If LED is for you this would be the correct style, not saying how well they will work.
http://www.ebay.com/itm/371011200794
Alan
Personally, I'd just skip all the LED BS and just make sure the regular lighting system is 100% up to snuff. Go up to a higher wattage if need be.What is the difference between Narrow and Wide viewing angle?
Some of our bulbs are available with Narrow or Wide viewing angle. The Wide angle (approx. 100 degree beam) will light up more area but dimmer than the Narrow angle. The Narrow angle (approx. 15 degree) will illuminate a smaller area but brighter than the Wide angle. We also offer bulbs with some LEDs aiming out the end of the bulb and some radially mounted LEDs aiming out the sides of the bulb. These will provide a more complete and even light pattern on the vehicle lens.
Leave the LED stuff to the AutoZone fanboys.
Probably not a bad idea, I was just trying to do my part to combat global warming...
