I have been flushing and filling my mud filled system for almost a year. Normallly I get out about two plus gallons. Recently I pulled one block drain plug and got out two quarts. I did not pull the passenger side since the drive side was clean. But, in refill, I went to the manual that says 17 quarts for non AC 66 fury with big block. I see one user here says 9 quarts...not clear on application. But, I just filled after draining one side of the block and it only took 2.5 gal of coolant. I thought that after the block drain would have been bit more. I have no idea about the heater core....prob half full?? The new radiator is the Summit OEM copper, large and three tube. So, I only got one gallon of glycol in and will measure the coolant later. But, curious what others have found on volume at refill. Thanks.
