SF-66TC
For those who have completed a Front Disc Brake Conversion, could you answer the following questions -
Please state whether you did a Factory Spindle Conversion or other ie; Scarebird, ECI, Master Power Brake, SSBC...
- Was there a difference in brake pedal height (higher, lower, same)?
- Was there a difference in brake pedal feel (hard, soft, cushion-like)?
- How far does the pedal depress before brake application?
- With the pedal fully depressed at its full range, how much space do you have left between floor and pedal bottom?
- What Master Cylinder did you use?
- What was the Bore size of the MC?
