mr gtx
i always remove the cover plate on the tranny and put on a screen. do you think this helps a lot in keeping the torque converter and tranny cooler ?
On the internet, I have read that the torque converter cover is too thin to hold in significant heat. I have a gravel driveway so mine stays installed.i always remove the cover plate on the tranny and put on a screen. do you think this helps a lot in keeping the torque converter and tranny cooler ?
I always wiped a lot of crap off of those covers. That told me that they are worth it.
WISE words! Accumulated dirt and gravel will sure as **** CAUSE overheating beyond the paltry convective cooling one might initially get from exposing the TC to dirty air. I explain to my little urchins that Clean Machine = Cool Machine.I always wiped a lot of crap off of those covers. That told me that they are worth it.
IMHO, any cooling would be minimal. Keeping the dust and crap out would take priority over it easily.
It seems to me that you have dirt and dust getting into the convertor area, courtesy of the open bellhousing area that's now a undercar scoop. ....
At idle it is not making heat. If so every auto trans car in afternoon traffic jams would be overheating. Converter makes heat when you put power through it.The biggest heat generator in a tranny is the torque converter. Heat generation occurs as a result of designed slippage inside the converter. The biggest slippage occurs when you come to a stop and idle the car in gear such as waiting at a light. In heavy traffic the best thing to do is put it in neutral while waiting. A cooler also helps.
