challenger
I am still chasing my tail with the Edelbrock 1411 carburetor on my 1970 300 vert.
The issues I have are a very slight stumble from a stop and while cruising and letting off & getting back on the throttle and a detonation at light throtlle while cruising. I completely disassembled the carburetor again and cleaned it. There was a tiny bit of material in the idle tubes which I took care of. This seems to have helped. The stumble is very slight and the detonation occurs at a very specific throttle position at highway speed.
I have the largest primary jet .113 and the smallest metering rod installed as well as the strongest step-up spring.
I tried lowering the initial timing to 5* BTDC from 12* and this has no effect at all on the detonation although it does make the car slower from a stop.
I thought my distributor was a Mopar Performance unit but it is not and I cannot see any way to adjust the vacuum advance.
I'd like to see if limiting the vacuum advance threshold would have an effect on the detonation. The stumble is something I can live with but the detonation is right at cruising/highway speed and is going to ruin the motor I fear.
I know there are no vacuum leaks that would cause a lean condition.
I feel it is down to vacuum advance timing OR the 1411 is running partially off the idle/transition/cruise circuit and is still too lean. I've been trying to talk with Edelbrock but cannot get through to see if possibly opening up the idle tube or changing something else might give me driveability.
As a strange idea-I have the original Carter off this car and the metering rods are identical in shape & length but the carter rods, according to the FSM, have three steps. The rods are a good bit smaller in diameter however. I'm wondering if anyone has tried these in an Edelbrock AFB/1411?
Thanks
Howard
Thanks
Howard
