1Fury1
Slab Side Slacker
This has been a huge hurdle for a novice like me but at last this weekend the clutch and brake pedals are working really good. The firewall is pretty well done now, and after I get the brake lines figured out the focus will be on getting the engine and tranny installed.
Here is the end result:
- Fabbed an extension on the brake MC plate to provide a solid support for the clutch MC.
The plate had to bend down 11/16" to meet the pedal bolt above the speedo cable.
Behind the scenes:
- A new hole in the clutch pedal lever at the location that provides 1" MC stroke.
- The clutch MC linkage is adjustable through the threaded pin.
- The pin swivels inside a bronze bushing that was pressed in.
- The old post is where the return spring goes.
Behind the scenes:
