Hello All!
Sorry guys, tried to delete this post since I realized there was a cooling/heating/A/C Forum and also posted there.. can't figure out how to delete this one though.
Im hoping some of you could share your experience flushing the radiator and block with a citric acid solution. The 383 in my 1967 Fury(GG) is still excreting brown water even after several flushes with just water, and one with a flush product added.
My radiator flushes clear by itself, but when it circulates through the block the water is still coming out brownish. I was told that the radiator was re-cored when I bought her 2 1/2 years ago.. but it seems like maybe a lot of stop leak may have been added at some point.. IDK for sure.. but the engine did sit for several decades without coolant changes. There are no signs of coolant leaks, internally or externally... and I don't want to create any! I've read conflicting accounts on the interwebs about citric acid. The standard protocol seems to first "degrease" the passages with a Dawn or Shout flush, drain, then a citric acid solution of 1 lb of citric acid dissolved in a gallon water, into the radiator, then fill the rest with water, and run/drive car for 15-30 minutes. Some say drive it longer, then flush. A few out there claimed this weakens water pump gaskets, etc. and caused leaks. Many others say it works great. So I ask you kind C-fellows-- any advice/ testimonials?
Thanks, Alex
ps. Also, where do I get an adapter tee/flush kit for garden hose attachment to the upper radiator hose. I want to run water in through the water pump housing(snugly fit) to pressure flush the block.
Thanks, Alex
