Fuel line fitting help
Newport 66
Lancaster, WI
I've exhausted my local possibilities and internet searches have provided little help.
This is a 5/16 x 5/16 x 5/16 "T" any ideas?
I should have mentioned that the end that goes into the carburetor as pictured is a male 5/16 the other two are female 5/16
I saw one of these before, so I looked and I think this is what you need. I looked at a fittings catalog and here's what I found.
Weatherhead #1514 / Edelmann #261520 / Everco #1514. This is the piece that screws into the carb and then into the tee.
Edelmann 261520
https://smile.amazon.com/Edelmann-2...ywords=261520&qid=1557879385&s=gateway&sr=8-3
Then a simple 5/16 inverted flare tee. Weatherhead #702x5 / Edelemann #130555 / Everco #702D
https://smile.amazon.com/Tomkins-13...ywords=130555&qid=1557879300&s=gateway&sr=8-3
I presume you looked in the 426HEMI restoration vendor catalogs under "Fuel System" items? Or possibly in the 440+6 or Corvette 427 3x2 carb fuel line set-ups?
Not everybody might have those in stock, but they usually were NOT specialty, "one-off application" items.
426 Hemi used a regular inverted tee that was 3/8.
What's the problem with the original one that you need to replace it?
Why do you need it? Replacement? New install?
Big_John has the best info thus far. Some disassembled pics of the fittings would be helpful, or some details about the set-up. I'm handy with tube fittings (ship engineer is my trade). I know an "old school" carb man nearby who may also be able to help.
This is a dual quad installation on my '62 300. Factory cast iron intake, using 1406 edelbrock carbs. 5/16 fuel lines and fittings.
I've looked at your dual Edelbrock photo, and compared it to the "original type install" photo in your first post. Several observations-
Your current Edelbrock 1406 setup appears to have two adapters already stacked-
1st adapter- 5/8-20 male (inlet size of carb according to Edelbrock website) to female ???.
2nd adapter- male ??? to female 5/16 inverted flare.
I recall that all high performance Mopar fuel systems used 3/8" fuel lines. With this in mind I researched and found-
5/8-20 male to female 3/8 inverted flare carb inlet fitting. (edelbrock # 8090)
Edelbrock Square-bore carburetor inverted flare fuel inlet fitting
An inverted 3/8 flare male x female x female (run ports to branch ports) was found here-
Brass Brake Tee Fitting, 3/8-24 IFF/IFM
I believe using these fittings (in lieu of what you show in your dual Edelbrock photo) will allow to closely replicate the OEM set-up.
Glad to see you hard plumbed it correctly. Too many times have I have seen all rubber lines because someone didn't know better.
When you put the distributer back in, you'll probably find some tweaking is needed.
