Fuel Tank Filler Neck: 1971 vs 1973
1970FuryConv
Richmond, VA
I was trying to match up a correct fuel tank filler neck for my 1971 Fury. I got a filler neck from a 1973 Dodge. I think they are a match but the 71 Fury mounting bracket may be taller, so 73 filler neck does not bolt in.
Anyone have a Hollander manual to see if 1971 Fury and 1973 Dodge Polara/Monaco fuel tank filler necks are the same number?
Thanks
The fuel filler is likely to be a bit higher on the '73 Dodge than on the '71 Plymouth.
Appears to be confirmed by different part numbers.
There was a mid year change on the '71 Plymouth: 3466856, 3583524
1973 Dodge: 3642089
Jeff
Thanks, Jeff
I found my 1971 Filler neck, so I need to take the tank down and switch it with the 1973
