Fury side moulding removal ?
valerianmagnum
montreal
Hi guys , i wanted to know if the side moulding of a 68 fury can be removed with basic tools and if theres 20 x holes or its 1 at the beginning and one at the other hand ? I want to remove the side moulding on the car that i have a deposit on, thank you
In addition to the bolt type clips at the ends, there are plastic clips that slide into the moldings that mount on “tits” that are welded to the quarter panel. Therefore, if you remove the moldings you will have to fill in several holes and grind of a lot of “tits”.
