PH27L7
There’s a lot of misinformation out there regarding interchangeability between B, E, & C body disc brake boosters from 60’s-early 70’s. Just removed an original booster from a 1970 B for a detailing so I thought I’d compare it directly with the original from my 1967 Fury which I’m sending out for rebuild.
Good news is they are identical in every respect except for the length of the pushrod which is 3/4” longer in the C-body and possibly the check valve means of attachment. There should be a way to extend the pushrod of a more common B-body to make it work on a C. I’m not sure how the pushrod is removed from the booster. They did change the means of attachment of the check valve from a twist on type with gasket to a push-in type with grommet some time in 67-68 but either works the same. They do make a repro B/E-body boosters although they look a bit different than the originals.
Some measurements I took-
Pushrod diameter- 0.500 in
Pushrod hole- 0.578 in
Pushrod swivel bolt diameter- 0.567 in
Stud center-center mounting to firewall- 3-1/4 x 4-1/8 in
C booster is on left in pics.
