For Sale Good working Mopar Washer bottle pump 1964
boltupal
Feedback: 2 / 0 / 0
Looks good squirts good. 25.00 Dunkirk ny 14048
If that was a Mopar part, it'd have a Pentastar stamp on it! Will still work with Mopar though. GLWS
Mine looks almost identical to this and it says MOPAR and has the part number on the bottom which isn’t pictured very well above. Additionally mine don’t work so I’ll take this one please Al. I’ll text you pal.:thankyou:
Ford ones are virtually identical - if you ever need a new one, the hot tip is to go to a Mustang vendor. You'll pay as little as $25, vs $50+ from a Mopar vendor! (I'm cheap!) And I'm not sure that all of the original ones had a logo, or part number. These were made by the millions, and I don't think the outside supplier was very picky when they shipped them out . . .
Also, if you have a good original case, should be really easy to just swap the guts. A lot of the new cases are too shiny . . .
You can carefully bend the tabs, remove the cover and inspect & repair what the problem is, unless you've literally cooked the motor inside? I've repaired a few. Good Luck
Mine looks like it’s seen better days however it does spin manually but shows no signs of life when tested. Plastic pump part is cracked too.
Even putting power to it and giving it a kick spin doesn't get it going? That does look like it's seen better days, do a cover swap with the other one? GL
If this was posted yesterday I would have bought it. My pump works fine be but the plastic disintegrated. I ended up grabbing a new repop from CJPonyparts.
The mustang pumps don’t line up with the screw holes. We made the correct bases so they bolt up correctly
doh! Anyone need a look alike washer pump that nearly fits without modifications? The Mopar stamp is on the mounting plate. You’d have to drill out and re-rivit to swap the guts.
I did not know this! They appear identical outside of stampings.
Yeah, and the one I bought from Van's needed a new hole in the header panel to mount. Wish I'd known QQE had one that matched original and that Van's didn't........ hindsight is 20/20?
Do you know what year an model of ford? I’m interested in replacing mine and saving money!
